Resetting ecu
suprahabsfan
Boost Addict
Sep 28, 2007
328
Sylvania, OH
I have a problem with code 52, and have done searching on here, and the general concensus is that they rarely go bad. so.... i've heard that resetting the ecu can help with the problem. Can anyone tell me how to do this? I tried searching for it but the word ecu is under the letter limit of the search feature? I really wanna get it fixed because everytime i boost with the code on it feels like its draggin ass because of the retarded timing!
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
just pull off ur neg on ur bat for about 10 mins. (some people pump the brake pedal just to make sure not necessery)
wallah ecu reset or u could just pull the efi fuse in your engine fuse box :) first 1 on the right hand side 15amp i think
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Pull the EFI fuse for a couple of minutes to reset the ECU. I hate resetting the clock and stereo after disconnecting the battery. ;)
Code 52... Isn't that knock sensors? The wire to the knock sensor DOES go bad. Some thin coax wire does a good job as a replacement
