Greetings everybody!
I'm about to embark on my project.
I'm burning enough oil on startup and hard accelation that I've decided to do a valve stem seal replacement.
I've reviewed the SOGI procedure and it seems clear enough. As long as I'm in there, I was considering swapping out the OEM headbolts (torqued to 58 ft-lbs.) with some ARP head studs. I'm thinking if I remove one bolt at a time and follow the torquing pattern, that I'll be alright.
Has anyone else done this? Any thoughts/obvious flaws in my plan?
Also, is there a figure that the stud itself should be torqued into the block?
Is there anything else that I should be replacing while it's apart? I'm going to do the cam cover screwbolt "mod"... anything else?
One last thing...OEM toyota stem seals are best choice?
Thanks.
Josh
Thanks.
Josh
