replacing head gasket
apexi287
401
Knoxville, TN
ok ive changed my mind and decided to replace my headgasket for a MHG and ARP studs since my valve stem seals are leaking anyways even though my headgasket isnt blown...anyone and everyone tell me what all i should replace during this process from clamps and hoses to cam gears and whatnot...i want it to be running flawless when im done and i want to do as much as possible to make it that way im sick of doing small things to hope it will slowly get better im gonna stop running it for a week tear it down do everything and everything right..so what should i do..thanks
also what MHG should i go with and mm size?
doom26464
Research...research
Saskatoon SK, Canada
all the gaskets and seals, spark plugs, possibly turbo(if yours is fucked or u want to replace it) probaly some other things but can't think of them right now.
apexi287
401
Knoxville, TN
i just did a turbo upgrade so thats good but ive been having issues with that but thats in my other threads..also just replaced plugs and wires two days ago
Apexi: As many of the coolant hoses as you can replace while the head's off.
Cheap insurance for the future they cost a bit from Toyota but are a LOT cheaper than another rebuild as our motors are intolerant of cooling failures.
