whats a good size turbo to replace the stock turbo on a 7m ?
-jdmmk3- slip n slideeee Mar 23, 2006 66 0 0 : las vegass : Mar 27, 2007 #1 whats a good size turbo to replace the stock turbo on a 7m ?
M MKIIINA Destroyer of Turbos Mar 30, 2005 1,825 0 36 41 Plano, TX Mar 27, 2007 #2 it depends if you are going bolt on and how much hp you are trying to hit. my personal favorite is the JT61GT. Good powerband with area to grow into. the best bet would really be set a hp goal at a certain boost, list your mods and ask again.
Sawbladz Supramania Contributor Mar 14, 2006 1,727 0 0 Oshawa, ON, CA Mar 27, 2007 #3 Thats about the most open ended question I've read in a while. Congrats
AF1JZ Almost civilian status... Jun 26, 2006 3,109 0 0 Fredericksburg, VA Mar 27, 2007 #4 -jdmmk3- said: whats a good size turbo to replace the stock turbo on a 7m ? Click to expand... Do some searching man. I'm sure you'll find what you need. Plenty of topics around here. But, easiest would probably be the upgraded CT26. No modifications on that side of the engine.
MDCmotorsports Offical SM Expert: Turbochargers SM Expert Mar 31, 2005 4,194 2 38 43 Indy 500 www.MDCmotorsports.com Mar 27, 2007 #5 Since your question is so vague.. Q: ^ A: Another ct26.
supradavenz LOL HIES! Apr 1, 2006 159 0 0 38 AUCKLAND, New Zealand Mar 27, 2007 #6 MDCmotorsports said: Since your question is so vague.. Q: ^ A: Another ct26. Click to expand... An upgrade would be something along the lines of upgraded ct26 compressor and flowed turbine?
trydrew Suprafied Nov 4, 2005 1,038 0 36 Earth Mar 27, 2007 #7 http://www.max-boost.co.uk/max-boost/images/big_turbo.jpg Why not? It has to be good for something? Really though, upgraded CTs, like everyone already said, are good replacements. It all comes down to how you want it to drive.
7Mboost 7M Powered Aug 15, 2006 2,201 0 0 Gainesville, FL Mar 27, 2007 #8 Upgraded ct-26.....use the search
