Replacement coupler size?
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Anyone know what I can use to replace the coupling from the 300 pipe to the Throttle body? Local Toy Dealer quoted me $50+ for the OEM one and....well.....screw that.
Also, what is the outer diameter of the stock turbo outlet? Thanks, the saga continues. Eric
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
you'll prolly need a 2.75" silicone coupler for the TB, you can make a 2.5 work with A LOT of work. I think thats right..
I believe that the stock turbo inlet is 3" or 2.75" as well.
BooST305
13
cali
i used this cheap little coupler from pepboys that cost 7 bucks.its a little long but works pretty well
jdub
Feb 10, 2006
10,730
Valley of the Sun
Just measured the 3000 pipe and throttle body inlet...both are 2.75" as hottscennessey said. Get a 3-4 ply silicone and 2 T-Clamps...much better and you're still out for a lot less than $50!
chriso
Supranian
Bay Area, CA
I bought a rubber coupling from Orchard Supply for like $4, trimmed it to fit and 8000 miles later it's still pliable and intact.
