Replace HG now?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Depends on what gasket you are going to put in there - if you are mounting a metal head gasket, then yes. If you are using an OEM style composite gasket, then check the head for warpage, skim it, and bolt it back together.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
In that case I'd likely suggest using the stock headbolts as well, they should hold a composite gasket just fine as long as you torque them to 72 foot pounds.
Unless you own a machine shop, you cannot skim the head yourself, it needs to be done by a pro.
clifftrail
128
Abq
If your car is running fine now and you plan on replacing it with the stocker, why screw with a good running car? Wait until it goes south if it does at all. My 2c.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Personally i would fix it now before it blows...
i don't say that usually, but the 7m's hg is a special case :eek3dance
thevork
ShoarmaTeam Member
TurboSupra7 said:
is it pretty pricey to get the head skimmed off? Over $100?
Always (!!!) Skim the head when replacing gaskets.
Even if it's not blown.
Your head will always warp when you remove it from the block, but especially now since your head is bolted on the block now for at least more then 12 years.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Well, at least always get it checked and be prepared to skim it. I have pulled off heads that were perfectly flat from the factory. It doesn't happen often, but it does happen.
TurboSupra7
139
Olathe, Kansas
is there an easy way to check if a previous owner replaced the HG already? I asked the guy I bought the car from but he had only owned it for a month when he found out his wife was pregnant and had to sell the car, so he didn't know much of anything about the car. Don't think I'm retarded for buying a car that I couldnt get info on...this thing is clean and runs excellent!
