removing the PVC hoses
If you remove the system entirely, which is not recommended - (the system improves ring sealing and increases power) DO NOT cap off those two large hose barbs - you need to relieve the crankcase pressure or you'll blow seals.
EDIT: you mean PCV, right? PVC is the plastic pipe you plumb your house with...
