In my quest to replace cam seals (among other things), I CANNOT get the bolt off the cam gears! I WRENCHED like a mofo, and not a budge. Any suggestions?
SupraDreamPDR said:if you dont have the above tools, which you should, then you could put a long screw driver in there to hold it while you wrench the bolt loose.
nosechunks said:take the valve cover off and put a wrench on the flat spots on the cam.
