I recall being told I have to loop the lines going into and out of the rack to keep some fluid in the rack. If I remember correctly its the line coming off the banjo bolt. Is this correct? Am I missing anything else?
Remove power steering pump and loop to/from steering rack lines to keep some fluid in rack.
Belt: Goodyear-4060390
New Idler Pulley: Dayco-49017 76mm 8 rib
Thank you
Thank you
