Removing importers writing on engine set
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
how did you all remove the writing on the upper timing cover???
mine has 1JZ and some numbers written n white how did you guys remove that?
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Brake or carb cleaner, some towels and some elbow grease.
You might also want to try some of those Gojo wipes. They are like wet shop towels with an abrasive cleaner soaked in.
The Reaper
Jan 10, 2006
1,909
Florida
^^^ yea i know i hate it
i used purple power degreaser on my intake mani to clean it up and MOST of the writing came of (the permanent marker came off but the white chalk paint stuff didn't) i was gonna use the purple power on the timing cover but you have to dilute it 10 parts water to 1 part PP and i didn't want to risk fucking up the cover. i'll try goo gone first as i really dont want to use sand paper on it as its a VERY noticeable piece when you open the hood lol
thanks for all the replies guys
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
sorry lagged that i replied negitivly to your post, but i didnt know exactly how that may react to the plastic of his plastic pieces that was painted
lagged
1991 1JZ
new rochelle
hey its ok! :)
ive cleaned the most nasty sttuborn stuck on disgusting shit off of fiberglass on the inside of boats with acetone. its very good for smooth non porous surfaces.
The Reaper
Jan 10, 2006
1,909
Florida
interesting i will try the carb cleaner and goo gone first and then step to the acetone if need be
thanks for the posts guys
The Reaper
Jan 10, 2006
1,909
Florida
nah im at work i will try it this weekend new house has a friggin 60 watt light bulb for the garage and its always dark when i get home so i do the stuff during the day
wiring harness will get started this weekend and then thats all
still needing a driveshaft tho so that sux but atleast i can get it installed and running without it
