Removing Emmisions equiptment on 90 mk3 turbo
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
the only emissions equiptment i would recomend removing would be the cat. check the vendors for a test pipe to replace it. leave the egr and vac canister.
99nbm
11
Missouri
Yea that was going to be taken off with the rest, i will just gut out the cast and leave em, in Missouri they have visual inspections. Also is my Supra a California car or something? it has 2 cats and 2 mufflers. Its soon to be 1 gutted cat and a Fart Can.
8,898
You can ID a California car by a temp sensor in the exhaust area monitoring EGR flow.
Don't remove the "smog" equipment. It does not cost you any power. If you have a track car, that is different. Even the EPA will allow it if you never drive on a public road again.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
i was thinking of welding the shell of my old cat somewhere on my catless exhaust just in case a cop were to look under there. did that ever happen to anyone? anyone else have that idea too?
8,898
By the way, a gutted cat doesn't flow worth a shit compared to an off road down pipe. And if you are caught, you will owe uncle sam a hefty fine. Get a real downpipe, and save your old.
catback
bitterville
i thought of doing that, BUT.....
if a cop does look under there and sees a tampered cat. you might be in trouble:biglaugh: (towed,impound fees, inspection, rapair.fines...)
it could end up costing a ton...
i got a magnaflow high flow cat << $85 cad and see through flow;)
i had a couple of police officers look down there and never said a word:evil2:
t4boost
I gotta have my boost!
Mar 23, 2007
106
Arizona
Speaking of emisions, do you guys see any problem with changing my timing so that i have valve overlap? I am tring to figure out a way to pass emisions when the time come since by then i will be running a RonR. FFIM with no egr. Do you see any danger in it? Think it youls work?
99nbm
11
Missouri
i gutted cat will flow just as good as a test pipe. its Hollow!!! anyways i believe ive got a cali car... that sucks.
figgie
Twin Cities, Minnesot-ah
big negative
you are increasing the internal diameter of the tubing which there by decreases the velocity of the gases. This causes back pressure as you are going from a high velocity portion of the pipe to a lower velocity area. Not a great idea!
Supracentral
10
Anyone who knows anything about fluid dynamics will be able to tell you how stupendously ignorant that statement is. But why fight it?
Since you already know everything, why are you asking questions?
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
If you want flow get a 3'' down pipe and hollow out the secondary cat and put a 3'' tube through it. So that whay it looks like you have the secondary cat and essentially you have a test pipe.
Adjuster
Crap, for all the work of hollowing out the stock cat, and then trying to shove a 3" pipe through a 2.5" hole, why not JUST BUY A HIGH FLOW CAT OF THE 3" VARIETY?
Just thinking outside the box here gentlemen.
The PD will not fault you for having a AM cat. "These are wear items Officer, and mine was worn out, and they do not sell the stock one for my old car, so the local muffler shop sold me this one"
You get the idea.
jdub
Feb 10, 2006
10,730
Valley of the Sun
:bigthumb:
