Removing CT-26 without draining coolant?
emiliorescigno
1,199
Woodbury, MN
Is it possible? The TSRM says you have to, but is there a way to just "block off" the coolant passages to the turbo instead of having to drain the whole radiator before removing the coolant lines?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I'm going to go with "no" on this one... The closest you could get would be draining about half of the system's coolant.
Sawbladz
1,727
Oshawa, ON, CA
I've never drained the coolant when pulling the turbo. I plug the coolant line with one of the bolts from the turbo support brackets.
emiliorescigno
1,199
Woodbury, MN
johnathan1 said:
I've always pulled the turbo without draining the system...you only lose about a cup of fluid...not a big deal really.
By "lose a cup of fluid" do you mean just letting it spill out of the turbo coolant hoses onto the ground until it stops?
johnathan1
Supra =
Aug 19, 2005
5,056
You can use a rag/towel to catch it, put some kind of container under it, or use vise-grips to pinch the end of the hose...or let it spill on the ground...LOL.
Even if you drain the whole cooling system, there will still be some coolant inside the turbo.
lagged
1991 1JZ
new rochelle
geez use your heads people.
first, remove the water lines FIRST, block off with two bolts.
be sure to do this BEFORE removing the ic pipes and most importantly, BEFORE you remove any oil lines. the coolant will spurt out and the chance of spilling some into the oil drain is high.
emiliorescigno
1,199
Woodbury, MN
Well thanks for the tips guys, hopefully this time around changing my turbo I won't have to empty my whole Koyo radiator...that's a lot of coolant that's just about new since I last had the turbo off...:icon_conf
go buy some hose pinch off pliers... vise grips work, but the pliers made just for the job won't harm the lines...
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Agreed.
Ive always just taken the water lines off and plugged them with bolts. It will be a little messy, but sometimes this is easier than draining coolant.
Sawbladz
1,727
Oshawa, ON, CA
annoyingrob said:
Is is really THAT hard for you guys to drain the damn coolant? Unscrew the drain plug, and leave it for a few minutes.
Why go to the extra effort and expense when it takes 2 seconds to just plug the line?
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i tried to remove the turbo chargers without draining the coolant and it ended up getting in my mouth. :nono:
