Removing Cold Start Injector
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
there was a post here not too long ago about cleaning the cold start injector. i cant find it. i need to do it. could someone assist me telling me where it is..and how much crap i gotta remove to get to it...and how... thanks.
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
its actually an easy peice to get at... took me a total of 30mins to remove, clean and reinstall... to clean it use like gas or kerosine you could even hook power up to it to get fluid moving through it... as to removing it there are 2 bolts holding it to the manifold and one holding the csi to the 2 bolt bracket.. i had to remove all three bolts to get it out... you have to move it in different directions to get it out though.. just with the shape of the manifold and all
i wish i would have taken a pic when i had it out... it was covered in crap
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
right in the "CROTCH" region of the upper intake plenum. its not hard to find. i disconnected mine since the sensor was busted for the coolant temp sensor so it new when the car was cold and what not. i live in florida so cold starts aren't too common to where you REALLY need it.
The Reaper
Jan 10, 2006
1,909
Florida
yes make sure you put it in a bucket or something first. unless you wanna risk burning shit down HAHAHAA
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
this might be a dumb question..but how do i know which terminal is positive and which is negative...
*edit* nevermind i got it
