relocating coilpack
bowsercake
828
Irvine, Ca
Not really an answer to your question but I heard that the stock wires will work if you mount your coil pack on the back of the engine. You just reverse the order of the wires, so, place the wire for 1 in sparkplug 6. This works because they both fire at the same time.
supra90turbo
shaeff is FTMFW!
MA, 01440
No, it works because you move the #1 plug wire to the #6 plug, AND the #6 spot on the coil....
You can make your own set of wires to whatever length you want.
Check out summit.
yankiwi
221
DFW
I used MSD universal wires, cut to length, and extended the coil pack wiring.
Hood clearance is about the same as when they are mounted on the valve covers.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Where did you get your ic pipe kit at? Also, how well does your catch can work without running off of the top two vacume ports the you have running back into each other?
supra90turbo
shaeff is FTMFW!
MA, 01440
They don't run back to each other. If you look, he's got the NA PCV Y-Pipe that connects the two valve covers together, then into one, which goes to the catch can.
The other port off the catch can is placed pre-turbo..
yankiwi
221
DFW
Yeah, the PCV setup is using the NA 2 into 1 deal. I can't really tell you how its working as I only just finished the build. Doesn't blow out the dipstick though so I guess its good so far.
I am writing up a thread in the build up section today and I will explain my hardpipes in that thread, don't want to jack this guys thread..anymore:biglaugh:
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
thanks guys"yankiw" that looks great. so moving it to the rear i would just revers the wires so number 1 wire would be moved to number 6 place and so on 2 wouls move to 5 and 3 would move to 4 and what not.
