Hey whats up. I built a custom CAI that goes down behind the headlight and i was using the MAF in its Lexus housing but that caused the air filter to sit way to low to the ground. So i removed the MAF itself out of the housing and installed it in one of the pipes closer to the turbo and now it doesn't accel. I have it facing the right direction but i have a couple questions.
1.These intake pipes are plastic, could the MAF possibly ground itself on its housing and is that my problem?
2. Where i put the MAF is on a 60 degree bend pipe, its right in the middle, but could it being on a bend be my problem?
3.Since these are Karman vortex would i have to install that mesh infront of it to generate the same kind of reading?
4. Does the shorter peg in the back of the sensor actually do anything? Is it a ground/temp sensor/something else, because i made a hole for that but maybe it isn't sticking down far enough. And in the Toyota/Lexus housings, the bottom of the MAF would set in a little round groove inside the housing, is that essential?
Go figure i try to improve something and F%*^ it up instead. Thanks for any help
