ahmed;1347551 said:right now i am takin it up to 7k on my bone stock 1jz making near 500hp..
is it safe to take it higher. or is it pointless with the stock cams.
mainly i just wanna know whats a safe limit.
Evilempire1.3JZ-GTE;1347712 said:My stock 1JZ redlined at 8000 I heard you can go up to 8300 on stock valve train.
With BC group buy titanium springs & cams you can go up to 9000.
The stock cams peter off at ~7300 so if you raise the redline it wont hurt but it wont do you any good.
RacerXJ220;1347837 said:I see you summed it all up there.:biglaugh:
ahmed, what turbo?
Evilempire1.3JZ-GTE;1347712 said:With BC group buy titanium springs & cams you can go up to 9000.
suprastanger507mgte;1347613 said:probably pointless with stock valve train. don't push it too hard or you can have some upper engine damages...your valves/springs/retainers may not be able to handle the high rpms. Stock cams will max out etc.
