Recommended Oil and Coolant?
faviles
SupraNoob
Oct 13, 2013
105
New Jersey
Just wanted to ask the experts what type of oil I should put in the beast after I'm done changing my BHG. Any specific brands? Or should I be able to go OEM? I will be running and OEM filter.
As for the coolant would I be able to use the following (stock radiator):
http://www.ebay.com/itm/like/251378002678?lpid=82
Or should I get the undiluted red coolant?
Car will remain stock for a while after the fix.
You would need 2 of those to fill the system. Just use Toyota red and a gallon of distilled water. Don't use tap or drinking water.
I run redline 5/30. Gc 0w30 is good as well.
Silver MK3
1,517
Madison, AL
Don't use an OEM filter, the WIX ones are much better. There's a thread here comparing the different brand of oil filter. As for the coolant Toyota Red, or Zerex G-05.
