recirculating bov disconnected = vaccume leak?
MattTerror
28
Ohio
I installed hard pipe from the turbo to the AFM. All hoses are connected except the BOV hose that vents to the intake. i wanted to finish up tomorrow so i go to start it up and it idles very low then stalls out. i checked all my vac lines and double checked and even took everything apart a 3rd time to triple check. it's all 3 inch pipe. only thing i can think of is the BOV not being recirculated or some wierd pressure change because the air filter isn't on. So i limped my way home and here i am. if i can't figure it out tomorrow i'm going to put the stock intake back on. :1zhelp:
