I just used one from an online supplier... The first one I received had a leak already and I recently got thru the hassle of returning the bad-new one, as well as the core. I'd recommend going with their cheaper rack since it includes the bushings. Since the 1st more expensive one turned out bad, should not be much more of a risk going with the $153 one. Things are working much better with the new replacement, to the new replacement.
The 1st one I received did not have the O-rings for the PPS/EVO deal, but the 2nd one did. You have to just unscrew the EVO deal off of the old rack (~1" wrench), remove the 2 old o-rings, clean the little screens, replace the 2 o-rings, and tighten back onto the new rack. VERY easy!
Local parts stores did not seem to have any racks for less than about $280, but most were above $300.
This thread gives you more info...
http://www.supramania.com/forums/showthread.php?t=89708
I have not ever had any issues with online parts until this time. I would have paid the extra $100 for a local one, if I did not have to wait for them to order/receive 'em either. Shipping a core back cost about $23. I did a better job packing than they did, so the box weighed about 28lbs,, instead of the ~$25 when I received it.
