...my 7mgte has rod knock(unverified now...maybe valve tap?), either way i was rebuilding it this winter. here's a link to my intro page...so you can see my sup:
http://www.supramania.com/forums/showthread.php?t=104794
i'm goin with a rebuild. here's my list of parts/things to do, open to edits of course:
*interested in what you've paid for these parts/services*
Part list:
-arp head studs/main studs/rod bolt set
-ACL bearing set
-Cometic mhg
-gasket kit
-ring set
-timing belt and tensioner
-waterpump, "cardon" brand?
-thermal barrier exhaust gasket
?helicoil exhaust studs
?arp fasteners
?forged pistons
?eagle rods ~$400
-take intake cam from my parts N/A
Machine shop:
hot tank ~$60
surface block ~$80
grind crank ~$90
valve job ~$450
hone&bore ~$100
inspect crank for need of cutting
Intake Manifold:
-ported/polished
Exhaust Manifold:
-ported
-ceramic coat inside/out
-wrapped
Head:
-3 angle valve job
-mild smooth intake port job
-cams, shims, buckets molydisulfied coated
-polish exhaust side
-thermal dispersment coating in/out
-remove protrusions in chamber between the valves
Block:
-moly coating: piston skirts, main/rod bearings, any bearing surface
-mirror polish of combustion chamber leaving some roughness
between the valve and fuel injector
-thermal barrier coating: crowns, exhaust ports, valve faces and combustion chamber
-crank and rods cryo'd
-machine/deck the block and inner timing cover together with
tensioner installed torqued to 36ft/lbs
Other info:
-ignite at 20deg after TDC, advance timing at different RPMs
to keep this true.
-water/meth keeps chamber/head/etc fresh and clean.
i'm compiling this list as a combination of many threads, rebuild threads, and technical discussions. also not neccessarily going to do every thing on the list...but it's possible if i win the lottery or just take my sweet time.
Part list:
-ACL bearing set
-Cometic mhg
-gasket kit
-ring set
?arp fasteners
?forged pistons
?eagle rods ~$400
Machine shop:
hot tank ~$60
surface block ~$80
grind crank ~$90
valve job ~$450
hone&bore ~$100
Intake Manifold:
-ported/polished
Exhaust Manifold:
-ported
-wrapped
Head:
-3 angle valve job
Block:
Other info:
to keep this true.
