Well I came back from korea, and started to finish breaking in my newly built 7M from 1 year ago. So I drive around and hit the 400 mile mark from the initial rebuild. I am running pig ass rich, with recently installed MAFT and SAFC together, with the 3.5 inch MAF.
So the engine felt great. I decide to boost to the wastegate's 10PSI to 4K rpm. It felt great, but afterwards I see smoke after I stop at a traffic light. When I accelerate theres a plume of smoke, and then it went away. There's a problem.
I take the oil cap off, and i see the tell tell signs of bad compression as I see smoke coming out of the oil fill hole in the valve cover. The engine has always had a missed idle due to plug fouling, so I decide to pull the plug wires one at a time to see which cylinder(s) is/are bad. So I pull number one out, and there's no change in the engine sound... After that thought to myself "do i really want to rebuild the engine again?" So I walk away.
I believe strongly it's running rich, because i keep fouling the plugs, and they smell like gas.
Could it have been I ran lean? I doubt it. The SAFC was correcting at -5% across the board.
At times it won't stay idle, it will just die.
So I'll be taking it apart eventually, perhaps tomorrow to verify whether or not I want to rebuild it or not.
My wideband is scheduled to arrive tomorrow on the 17th... sucks for me.
The motor has basically sat without anyone starting it for about a year. during that time it was started and left to idle for 30 mins at a time maybe three times.... bad for a rebuilt engine not broken in.
I'm sick and tired of this crap. I used the rings which came with the ROSS pistons .20 over.
What are my options here for the rebuild. If the rings are bad, would regular replacements work or would I need to rehone the cylinders and buy new pistons???
Too much fuel damage the cylinder walls perhaps???
