I just bought a used ct26 turbo , the kid who had it said it could use a rebuild , somthing happen where the compressor wheel was chipped , I was wonder if it would be hard to do it my self or to have some1 else do it ! I was lookin at the rebuild kits they have on ebay , they dont look too bad for $150 ..... it comes with 2 journal bearings ,,, 1 oring seal plate , 1 oring compressor cover , 1 piston ring t/e , 1 piston ring c/e ( compressor end ), 1 thrust collar , 1 thrust spacer , 1 thrust plate , 1 thrust bearing & shaft nut ! A new compressor wheel & the old Ct-26 should be a Beast for the N/A-T project..... :biglaugh:
