how difficult and what specialty tools will be needed if i choose to rebuild the 7mgte engine on my own , minus machine work needed? is this anything you guys have done? any good/bad stories you have to share?
is this needed if i have machine work performed. aka bore hone etc?Shytheed Dumas said:Ridge reamer fits into the cylinder and takes the crusty ridge that builds up at the top of the cylinder with time. If you don't remove it, you won't get the piston out without destroying the rings and maybe (and far more importantly) the piston and/or scoring the cylinder wall. The one I used was a serious PITA to align perfectly parallel to the cylinder walls, but I eventually got it done.
88YotaTurbo said:how difficult and what specialty tools will be needed if i choose to rebuild the 7mgte engine on my own , minus machine work needed? is this anything you guys have done? any good/bad stories you have to share?
Me as well. I just had to take everything off the short block and just sent in the head and the block and they will do it all for me.Deathseeker31 said:depends on the machine shop. my machine shop actually took care of that for me but if you are wondering you can ask your machine shop and they will be able to tell you wether they will do it or not.
