My engine is currently being rebuilt. The block and head were both machined extremely smooth. The MHG I am using is a 2mm HKS Stopper. From reading the posts I have always read people using either the silver spray or Permatex brake quite to seal the gasket. However my mechanic said a sealent should not be used with the HKS MHG. He told me HKS specifically says not to use any sealant. Apparently the MHG has a thin rubber coating on it which makes the seal when you torque it down. Is this true. What are peoples thoughts.
