SupraDreamPDR said:
ok. i am probably going to try and reuse the stock rods and maybe get some stock sized pistons, if the stock ones are no good (Like Nippon racing or new stock Toyota pistons). dont really want forged, cause i heard it causes piston slap on warm up and idle. i am probably just going to have the shop rebuild the head and block, also have them balance the crank and rods and pistons. then i will reassemble the rest of the motor, everything not internal. so need to get a full gasket set, can i just get the ones off of Ebay? What RA spec for a GReddy 1.5mm MHG?
I've got Ross pistons and they don't slap at all. The manufacturers have tightened up the spec on piston clearances...slap is not the issue it once was. The only way you will be able to use your current pistons is if the cylinders are still in spec...i.e. not out-of-round w/ min wear on the walls (good cross hatch still there). Then a hone with oversize rings will work and save some $$$. If a bore to oversize is required, you will need new pistons.
Don't have experience with Nippon, but I've seen the Wisco forged pistons and they are nice with out killing your wallet. Forged pistons give you more of a safety factor...if the price is close for either, go forged. The stock rods are very strong and will work up to pretty high HP numbers. Consider using ARP crank and rod bolts.
Get a Toyota OEM gasket set from Jeff at Champion Toyota.
The RA spec for the Greddy is in the 20-30 range. I'm a fan of the Cometic MHG...it's cheaper and more forgiving on the RA...it's spec is 50 or less and it works well. You want to remove the rivet on a Cometic before you install. In any case, get the machine shop to deck to the lowest RA their machine is capable of doing. Check this out (stolen from IJ
http://www.babcox.com/editorial/ar/eb70228.htm
Also, the thickness of the MHG will be determined by how much material is removed from the head & block...the stock gasket is 1.0mm; take the amount removed from both and add to 1.0mm for the correct thickness.
Make sure the machine shop understands a couple of things:
- The RA on the head and block must be at spec or below
- Crank bearing clearances are critical...the tight side of spec is preferred. Toyota makes different oversize bearings to make this happen.
- The valve shim clearances need to be mid-range...too tight can cause a bent valve. The valves will likely need to be re-shimmed after break-in at some point.
- Check the shim clearances and cam retainer torque yourself.
- When you're putting it all together, torque spec for the ARP hardware should be used following the pattern in the TRSM. Don't over torque!
As you go...do a search here for your question first, read up on it. Ask a question if you can't find the answer and somebody will help ya out
