Thanks for the information,
I am pretty sure my head is broken, because my valves are knocking when the car warms up, it's pretty loud. Also I not sure if I want to take this head in for a rebuilt because the head is old about 150k miles on it.
Another reason why I think my head is broken is because when I took off the head to replace my piston rings which melted onto my piston. I aligned the cam gear of the top head to the alignment mark and I believe the valves didn't line up correctly. I am not sure if it was normal or not and it’s been a while but I believe the intake valve side had four valves on two of the pistons that were open. Two of the intake valves for one of the piston were fully open and the other two were about half open. On the exhaust side, only two of the exhaust valves for one piston were open. (Don’t remember exactly which pistons they were)
What should the right alignment of the valves be if the cam gears are aligned with the timing belt alignment mark? What valves should be open and how many valves should be open at this point?
I not for sure what is wrong with the top head but I believe all my problems are coming from my head. I have lack of power when I quickly step on my gas pedal and the cars also dies when I quickly step on the gas pedal. If I slowly rev the car, the revs ok and doesn’t die. I check my codes and they are fine, I check my AFM, Turbo, and Throttle position sensor and they are fine.
I am thinking of buying a new rebuilt head off of Ebay for $425+ shipping. Does anyone have a good head I can buy for a cheap price?
Thanks
