rebuid Question....
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
okie right now im rebuilding my engine i just put in new gaskets etc, bov, upper strut bar, k &n filter, and silicone hoses from hose techniques.....i inspected turbo its fine im not planning to replace in a while.....
question is where do i go from here......
i was thinking of replacing all those brittle hoses then, all ic pipes, intercooler, CSF radiator, exhaust package (all 3inches)that comes with a high flow turbo eblow, 550 injectors(low imp) , lexus afm, and areo FPR then walbro
what do you guys think.....ne other things what are more important or missing?
or should i focus on my transmission first....?(r154) its a little sticky ... but i know i do need to change it..... is there just the clutch and flywheel in the transmission or is there ne thing else???
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Good list. Do the IC pipes and IC as a unit, and buy a set that's made to work together.
Same with the 550cc injectors and the Lexus AFM.
As for the tranny, replace the fluid with Redline MT90 and it should smooth out.
