Does the Supra use the same axle splins as other toyotas? I am looking into gettin a detrioit locker or some time of ratcheting spool to lock the rearend. Anyone know the # of teeth or if its the same as other Toyota rear end axles?
The axle is not the problem.
The inner race of supra bearings does not fit onto toyota truck difs. So far I don't know of anyone who has found a "hybrid" bearing that will mate the truck carriers to the supra case.
so is the axle teeth the same as the other toyotas, bear with me I might be on to somethin, I am not tryin to mate the truck carriers to my rearend, the spool would replace the carrier if the teeth are the same mesh
