rear windshield washer not working?
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
so my rear windshield wiper squirter wont spray water when i turn the knob but i can still hear the motor running so i dont think the motor is bad, it has fluid because the front one still squirts, help?
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
check the lines to see if theyve come undone anywhere along the way to the back. Maybe a clog. this might be tough as they run through the interior but start with the easy places to get at. Maybe feel around the back for some wet spots, that would be a good indication the the hose is not connected
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
There really isn't much to this system. You're probably looking at a clog or a pinched line, and the procedure for both is pretty much the same - pick up some extra line and run a temp straight to the nozzle. If it works then, work your way back along the line, plugging it in and testing it from every join, until you find the offending section, then replace that.
If it doesn't work with the temp line, check the nozzle itself.
The res. is low. The pickup for the rear sprayer is higher than the front sprayer so if the back stops working you'll be out of fluid soon.
