rear wheels locked up
lesky33
8
ohio
Recently the rear wheels on my 89 supra locked up. I thought maybe the brakes froze since the change in weather but after seeing it pulled onto the flatbed and still not break lose im stuck between thinking the rear differential went or something along the lines of the tranny but it still is able to go into gear. Right before they locked it made a horrible grinding sound ive never heard before.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Before you even go there... push in the clutch with the car in gear and see if they spin. If so, it's the motor.
If they still don't spin, take it out of gear and try it again. If they spin, it's the tranny.
THEN disconnect the driveshaft...
lesky33
8
ohio
i took the drive shaft off and it spun. the rear end is locked. Unscrewed the drain plug off the rear diff and not a drop of fluid. Already pmed someone for new lsd. thanks for you help
Buddafucco
Beef Supreme
Mar 3, 2007
214
Tampa Bay
Didn't mention if he was driving when it locked up. Locking up at 80mph makes for a much more entertaining story.
It makes a big difference knowing if the car was actually moving and if the engine stopped running, and which end of the car made the grinding noise. If you think the brakes froze due to weather then you must not have moved the car more than a few feet. Freezing brakes, I'm from Florida and just the thought of it being that cold gives me the shivers.
Frank Rizzo
478
Fixing your girl's car
Just read this thread and my first thought was no fluid. Because mine only had .5 quart (1 pint) of thick grey substance when I flushed it the day I bought it. The axle seals are the main culprits with the pinion seal being a close 2nd. The thing only holds 1.1 quarts its whole life, not much room for error. I check mine every year, I don't change it anymore because the drain plug threads in the diff are about as soft as the exhaust manifold stud threads in the cylinder head, can you say soft ass aluminum?
mkIIIman089
Ohio
The diff casing isn't made of aluminum...
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
isn't dry weight around 85lbs? i switched out my blown diff thursday night and finally installed my LSD. boy was that no fun. 24 total stubborn nuts/bolts IIRC. i forgot what Jose had me use, but it made WD-40 seem like water.
cuel
1,536
Baytown, Texas
I don't know, but it sure is heavy. Swapped to the open diff out of my parts car so I can rebuild my lsd. Used a trans. jack to get it up in the car.
