REAR SUB FRAME
Bowser
14
Bay Area, CA
If i were to change my rear sub frame with a newer one will i need to get that sub frame aligned when it is bolted on to the car??
marlonvip
Supra -only way to fly
Sep 2, 2006
189
Denmark
Hmmm I didnt, but dont really know.............?
There is 4 major bolt and some smaller ones on the subF where would you go about adjusting it??
Marlon
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
The frame itself bolts onto unadjustable locations but.....
-The old frame may be tweaked a bit and the car was aligned to compensate
-The new frame might be off compared to the rest of the car
-If you re-use your suspension arms the alignment will be disturbed upon assembly
-If the new frame comes with arms, who knows what the alignment was..
At least have it checked when you are done, some places will even do a check for free in hopes of selling you the alignment you are probably going to need anyways.
shaeff
Kurt is FTMFW x2!!!!
11
Around
and if you have it out anyway:
-beadblast and coat with POR 15
-bend the metal tabs behind the eccentric lobes back to 90* and run a bead of weld behind them to prevent further movement
-replace the subframe bushings
-possibly reinforce the subframe where it's prone to cracking (search- there are pics)
-shaeff
