Unfortuantly I had to choose between my supra and my grandpa's car. My grandpa's car won.
This is a project of a huge scale, at least it seems that way in the planning phases. I have a 1956 Chevy Bel-Air convertable that I'm converting to a LBZ duramax (350hp, 650ft.lbs) and will be using the 6 speed Allison automatic.
Extensive modifications to the chassis will be needed to fit this combination in the car. My current plan is to use the mkIII rear subframe and obviously the IRS. I want to go twin turbo to get the right exhaust note, so I wouldn't mind turning it up a little.
My question is, in your opinion what is the maximum torque the diff and axels can take? I'm hoping to keep the total vehicle weight under 5500lbs but I don't know if that is possible or what the weight balance will be.
