rear strut relacement, underway....I need some help
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
Okay, I'm putting in the rear struts and the bottom of the strut is to far down, it will not line up at the bottom. Is there an easy to compress the strut to get it to line back up? Am I missing something here?
As always, thanks
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
here are some pictures if I was unclear.
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
jdub;1002468 said:
Three words: Coil Spring Compressor
the spring compressor just pulls it away the top down instead of the bottom up. I tried it already.
Oh, perhaps I should mention that the springs are b&g, not factory.
sogi99
115
Elk Grove, CA
you need to unbolt your swaybars both side so you can extend the arms down just my 2 cents I did both my friends and my supra 2 weeks ago
EOS
Obsessed with photography
Feb 27, 2008
45
St Louis, MO
On mine, I used an impact gun to unbolt the swaybar link, gently pried the suspension arm down slightly with a jack handle, and slipped the bolt through...no problems at all...
