#04;1897511 said:^yep the steering rack brackets are a-symmetrical, I ended up removing USDM 87 steering brackets and welding them onto my 92 front subframe, they are 3/4" (IIRC) difference in position..
adampecush;1897588 said:You can sort of see in this photo where my body guy cut out the old panel (the white filler line)
Absolutely.KWITTS;1897650 said:Ouch .... So instead of cutting and welding my lhd subframe would just bolt on ?
KWITTS;1897651 said:Thanks for the pics man ... Yea that looks more like it. Cut before the tail lights and the door jam is all I think it may need ... Depends on what it looks like after I take out my rear interior ... Or I could try the swap the fire wall stuff ... In the end do you guys think if I really want a lhd that swapping it would be less work than just replacing my rot
KWITTS;1898122 said:Does cutting and replacing the quarter panels weaken the structure ?
