rear main seal
1-2clutch-u
379
chi town and ohio
I put some dye in my oil and i found leaks the oil hoses poped so that was obvious but some may have splashed up on the tranny. I cleaned it so ill check again today but how would i replace the rear main seal with out removing the engine from the car. alldata calls for 5 hrs but dosent tell me how to do it. any advise on how to do it bec. my car cant be in the shop over night. what other gaskets should I get also.:dunno:
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Motor in car: You would have to remove the trans and flywheel/flexplate to get to it. Don't see how else you could do that.:dunno:
j3pz
still learning
tranny would have to come out, and you will be working under the car. with that said, it will be alot easier to work on out of the car and then you can do other maintenance if you need to. if you have a shop with a lift, then have at it, drop that tranny
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=87
1-2clutch-u
379
chi town and ohio
will i have to take off tho oil pan? or just drop the trans and wala. I have pulled a block from a car before but i forgot what all I had to do to get to it. I do have a proper shop with lift and all the tools I need. I just don't need any suprizes to were my car sits over night and my boss will ask questions.
kwnate;1148760 said:
pull the tranny, clutch and flywheel. Replace seal. Reinstall flywheel, clutch and tranny. Get new flywheel bolts and replace the clutch if it needs be.
Where's the punch line? You can't post serious shit on here, you have a reputation to uphold........:3d_frown:
webbs7mgte
298
wisconsin
nice suprahero lol. but if i believe arent their like 3 or 4 bolts that go from the oil pan into the rear seal housing or am i wrong? but as said it will be tricky without pulling motor what i would suggest is. pull ur driveshaft and replace carrier bearing right away lol. and also drop your tranny and get that out of your way so you have a little bit of room to work than i think you could do it but will still be tight.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Don't need to pull the housing to replace the seal. Just be carefull when you pry out the old one and don't gorilla the new one.
