Rear Main seal question
Cya
628
Columbia, S.C>
Will a new rear main seal leak when its new? More specifically if the engine has been tilted nose up with a cherry picker at a steep angle?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Cya;1025974 said:
yeah, it sucks. whats the best way to do it?
by being innovative or buying a tool that helps the install of these types of seals (i did both and the tool was the cheaper route heh)
tlo86
Jul 24, 2005
3,914
Colorado
did you install it flush with the metal around it or push it in as far as it could go
castrol supra
Semper Fidelis
May 8, 2008
95
The Back 9.
Did you do it yourself or have it done???
Because I took mine to the dealer and had them do the clutch and the Rm seal.
And my shiznit is still cranked up.
I didn't have the tools to do it myself last time.
I'd rather mess it up once myself and learn how to do it.
Than pay someones' premium to screw it up :3d_frown:.
Cya
628
Columbia, S.C>
Im a DIY guy, I like to know how things work so I did it myself.
tlo86
Jul 24, 2005
3,914
Colorado
mines not leaking.......:sarcasm:
but my front main is and cam seals :( but those are easy to get to. either way i think i will doublecheck the rear main once i put my new clutch on
Justin
Speakers?
Spokane, Wa
I always have issues getting these type of seals on :( I'm just not very good at it.
My Cam, Oil Pump, or Front Main is leaking... I'm not looking forward to getting into that mess :\
tlo86
Jul 24, 2005
3,914
Colorado
i'll probably reseal my oil pump too when i get it off
