So this is going to sound stupid, and i feel stupid for not noticing this before.
When driving my 87 turbo i would hear a clunk from the rear end on acceleration, deceleration, and changing gears. you might think its a U-joint, or bushing or even something in the diff. I checked all that and then i noticed some basic shit:3d_frown:
The two front bolts on the Differential case that connect it to the frame were about a turn or two from being completely out!
I didn't think of checking them because i never messed with them but i learned to always check someone else's work. so if anyone is having trouble like this just check all the differential mounting bolts!! should be torqued down to 122 ft-kb (http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=RA&P=23)
