Rear coolant leak
enawazh
79
long beach
Just finish my rebuild. Went to fill up coolant and i seem to have a leak in the rear of the engine under the EGR plate. Thnx to Rusty89 i have found a picture of the rear and it seems the leak is coming from the circled area. WTF is that round thing? is it a freeze plug? Will i be able to stop the leak with the engine in the car? thnx guys.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
freeze plug... those should have all been replaced during the rebuild by the way...
sure its not that coolant union? or the coolant hose on top? or one of the 90 degree bends.
enawazh
79
long beach
i actually gave it to a machine shop, i got new plugs on the side's but i never really payed attention to the back. i guess im in a world of hurt now, what would you suggest. what should my next step be take it all of or take of the transmission and put a plug in
thanks for the input
yotasupra3
62
OMAHA
if its that freez plug i would youll prolly have to take the motor out but i would make sure thats not the rear coolent hoses check those first.
supraman7mgte
Shut up,bitch!!
Sunny California
i would check everything to make sure there are no leaks. that 90 degree bend hose is a bitch to replace with the motor in. just make sure eveything is good before you stuff it back in!
enawazh
79
long beach
UPDATE:
The leak was a MISSING freeze plug. The machine shop forgot to put one in. I confronted him and he said that hes never heard of a freeze plug on the rear and that he didn't mess up. I'm definitely not going there again. Anyhoo it was a 35mm freeze plug that goes right behind the hard coolant line. All is well.
92nsx
2,957
Clearwater, MN
time to find a new engine builder / machine shop. What they thought it was ok to just leave a 35mm hole in the back of the block open?
