rear brake light failure light
jessetooslow
551
Tiverton, R.I.
ok, so I think I have asked this before, but I know all of us has the rear brakelight failure on the dash. Is this the little white box under the taillight? Is there anyway to fix it? doe sanyone rebuild them? or can I buy new ones somewhere?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
So what specifically is the issue you're experiencing? I can't help if I don't know what's going on.
Are all the bulbs in your tails good and the lamp failure indicator is still always on? If so when does it come on? When you hit the brake pedal or when you turn the head lights on?
Wires generally don't disconnect themselves... are you asking for info about the common failure points of the Lamp Failure Module?
jessetooslow
551
Tiverton, R.I.
I'm not really sure what it is called, but I know alot of supas have the problem, the light is always on, I've heard the sawdering comes aprt, so the light in the dash stays on
