rattling noise from engine bay
Ca104
Dayton ohio
I'm getting a bad rattle from the engine at about 2500 rpm and up. Oil pressure Is good and it runs fairly smooth at idle. I've got a code 52 but that's it, it seems to be more prominent under higher boost levels. It sounds like valves any one else experienced this
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Sounds like detonation, does it happen more when it warm out or when you have the engine under load such as going up a hill?
Ca104
Dayton ohio
It's going to. Be hard to get a video because I only does this under load it is uncanny to a valve rattle but the head was just redone 6k ago
Rollus
593
Paris, France
jetjock;2050093 said:
Code 52 means the ESA system is inoperative. Detonation shouldn't occur under those conditions (nor should it with ESA functional) but why drive the car like that?
^^ This.
When my ECU is in limp mode, it has a ratling sound. I feel it like it's due to a slight hydrolock, because it runs piggy rich with minimal timing...
If not related to 52 code, considering it is under load and > 2500rpm, it can be something like a bent rod, a bent crankcase, etc...
