random hose help!!!
siikmk3
15
nova
i pulled the accordion tube off the inlet to remove the washers from my wastegate aka the shims. on the bottom side of the accordion tube there is a small hose just chillin. it wasn't hooked to anything does anyone kno where this go's. also it was reading 20psi on the vac side when i looked after i removed the washers it was at ten. is this normal car runs great and its still reads almost the same amount of boost but no fco im happy
-10 is not enough for vacuum. there should be a nipple on the bottom of the accrodion hose for the hose your talking about which goes down to the p/s pump.
siikmk3
15
nova
ok so i went back over everything and i put the ps hose back on. its still reading 11psi and i didn't mess with anything else. im stumped....... how much vac should it run stock i thought normal engine vac is 14 psi idk and suggestions?
89supra7mgte
797
colorado
my car is running right around 16-18 in at idle and then jumps to 22 on decel while driving. does your gauge fluctuate at all? check it for vac leaks and boost leaks. my car had a huge vac leak still ran great but had low vac. fixed and problem solved. leak was on the egr vsv.
siikmk3
15
nova
thanks for all your advise i have found the gremlin it was hiding in the boost guage::w00t::
