Wats goin on fellow MK3 Supra owners, i gotta pretty big problem on my hands and i need assitance ASAP! I have a 1990mk3 with the 7m-gte and it has 200,150 miles and its 5 speed. I keep up with regular maintenance so its been workin good for me (im saving up to fix it up but need more money first so its bone stock). MY SUPRAS PROBLEMS ARE that when i pulled out the spark plugs i noticed that they were drenched in oil and have no idea whats going on they also had a black tip so im going to replace them soon. Also it has a whining sound kind of like a super charger when its in first gear i dont know what its from. It also smells like gas sometimes idk where the smell comes from specifically, it also has a vacume leak i think in the hood side where the battery is because i hear a weird kind of hiss. When its in first gear, once you hit 1500RPMs it doesnt get any power even if you floor it until like 3 seconds later then it takes off! same thing in all the gears. And the last thing i can remember is it sometimes takes me like 4 tries to start it up in the morning before heading to work and i have to hold both clutch and gas down while giving gas some pumps so it will start. PLEASE GIVE ME SUGGESTIONS AND HELP! THANK YOU!!!
I want to weigh the difference and see if i should BUY A NEW 7M-GTE ENGINE or FIX THIS CURRENT ONE.
-Possible Vacume Leak
-No Power at any gear for at least 3 seconds
-Spark Plugs drenched in oil
-Gasonline smell
-Problems starting sometimes
Specs: Slightly bigger single turbo, stock 1990 Toyota Supra Turbo (7m-Gte), 5 Speed Manual
PLEASE LET ME KNOW WHAT YOU RECOMMEND -- ENGINE FIX or NEW 7M (NO I DONT WANNA GO 1JZ or 2JZ i wanna get all the power i can out of a original 7m)
-Gasonline smell
