Ok so I need to pick up some screws to mount the radio back in the car at lunch. And I left the only screw that I had at the house. What size are the screws that mount the radio back into the dash?
ForcedTorque;1846213 said:I call them Supra screws. Little black screws that are all over the car. There are a couple of different sizes, you need the smaller ones. I have hundreds of them in each size
Jeff Lange;1846219 said:Your post is a bit vague, though I think you are incorrect. The screws that hold the radio into the dash are not used anywhere else on the car. They're M5 machine screws that are 18mm long with an 8mm hex head (secondary philips screwdriver socket), they're quite uncommon actually.
Jeff
Jeff nailed it. Have fun trying to find them, I never had much luck...Jeff Lange;1846219 said:They're M5 machine screws that are 18mm long with an 8mm hex head (secondary philips screwdriver socket), they're quite uncommon actually.
Jeff
