Radio not working question ??
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
When i bought my supra, the engine was in a fire, and something shorted out the radio since it's not working, also the side mirrors aren't working.
So here is my question, how can i trouble shoot this,
I already checked the Fuses, everything is fine. I looked at the wiring diagram and from what i see, the wires connected to the radio, it's also connected to the side mirrors. I m not sure where to locate this in the car but if someone knows on how i can trouble shoot this, i appreciate it
thanks
Oct 11, 2005
3,819
20
Thousand Oaks, CA
You need to remove the radio and disconnect the power plugs. Then start by checking for power and ground on the relevant pins.
+B should have 12V all the time
ACC should have 12 V with the ignition on or in accessory position
GND shoul d be low resistance to ground
The rest are don't care for now.
This from Ishii on that other site:
The connections you should be looking at are the ones Labeled 10pin and 6pin.
Here is the wiring pin out of the 10pin connector:
1: FR+
2: FL-
3: ACC
4: +B
5: FR-
6: FL-
7: GND
8: ANT+
9: AMP+
10: ILL+
Here is the 6pin connector pinout
1: RR+
2: RL+
3: RR-
4: (usually unused)
5: LL-
6: RL-
By the way, the original factory radios are way past their prime and often have internal problems. This may be the case here.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Oh yeah, forgot about those, must be getting senile. :aigo:
For 89+, the following is true, not sure about 86-88:
Left kick panel is a 7.5A fuse they both share (E1). Also, there is a big junction box with 3 connectors from cowl wire to instrument panel wire (E3).
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=28
Stick a voltmeter on the gray wire on connector 3A pin 12 with ign on and should see 12 V there if fuse and power supply circuit is okay. That circuit feeds the radio and power mirrors.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=20
