Can I run an OEM 7mgte radiator on my 1j? Are there many differences or modifications to make it work? Any help is appreciated,
Thanks, Sam
Thanks, Sam
pocketrocket07 said:Can I run an OEM 7mgte radiator on my 1j? Are there many differences or modifications to make it work? Any help is appreciated,
Thanks, Sam
oscolivar1 said:Just save up for a KOYO radiator and skip the hassle of trying to fit the 7m RAD.
87soup said:Cool... I cant afford to lose another motor due to overheating!!!!!
jdub said:Trust me
You WANT a dual core radiator in Phoenix during the summer. Cut the jiggle valve off the thermostat for a small, constant flow through the radiator...don't run a stat less that 180 deg. Make sure your fan clutch is working properly. Check all your hoses in prep for the summer.
It's starting to get hot in the valley...the stock radiator will work, but you are at the limit of it's capacity to transfer heat during a 110 deg + day. And it needs to be in very good condition to do that.
