radiator support info
jimi87-t
1,127
5
Colorado Springs
Is your front end bent up? Or are you replacing it because of rust? If it's bent up, my advice would be to take it to a body shop so everything will be put back straight. But if your car is not bent, I would use some sort of bracing to hold everything straight and then cut out the old one and weld in the new one.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
yeah it bent up a little,but i may be ablt to fix it.
