do any of the aftermarket radiators (fluidyne, PWR, Koyo) support the use of the stock fan and shroud? i tried searching but all it came up with is a thread about possibly duane making a cf fan shroud...
IJ i figured you may be somewhat partial to them, i was going through your build-up and saw all pwr for cooling, is it easy to set up an air to water i/c like your set-up?
i'm gonna be calling around and looking for the best deal on my "parts for this couple of months" getting RS R exhaust and radiator is still up in the air
The Koyo is/was a jz rad (never seen an MA one anyhow), and requires some modification to fit. You need to make lower brackets for it, and plug a sensor port, but it's pretty simple.
i thought i remembered something like that but i couldnt remember which one it was for... it needed a different radiator cap also right? anyway i may also look into the csf 2 row alum. radiator also, if its nice it's only 299 instead of close to 500...
if your going for big horsepower than i would invest on the PWR and fluidine........but if not and are looking for 300 horse or so id go with csf radiator......
good luck
