look up the dimentions of each, as well as where the inlets and outlets are. if it's close or the same, i'm sure you could do a few modifications to make it fit...
I went back and did some more research on this. turns out it won't fit, because it appears that the inlet and outlet are both on the passenger side of an mk4, according to the pictures I looked at online....
