Does anyone know off hand the pressure capacity of the stock supra radiator cap? I think it's around 16 PSI? I want to upgrade to a slightly higher capacity for a higher coolant boiling point...
souprat said:went into the garage and had a look. 88Kpa which is how the civilized part of teh world says 12.76psi. it says right under all that kanji on teh rad cap. i hope all your rad hoses and lines are new because with the higher pressure you will certanly find out which hose is weaker.
It has become popular to install high pressure radiator caps in an attempt to lower cooling system temps. ...
....Before increasing your cooling system pressure by replacing your radiator cap with a higher rated radiator cap, check to make sure your entire cooling system is in excellent condition and all of the components are capable of handling these higher pressures. These may components include, but are not limited to:
The radiator (all of the All-Aluminum radiators that we sell are rated to handle these higher pressures)
Radiator hoses
Heater hoses
The heater core
The water pump
Freeze plugs
All gaskets that come in contact with the cooling system
Increasing your cooling system pressure by installing a radiator cap that has a pressure rating higher than factory specs increases stress on the entire system. Although some race cars use high pressure caps, their cooling systems are built to handle these higher pressures (All-Aluminum brazed and welded radiators, steel braided hoses, no heater core, high performance water pump, high performance gaskets, etc). We offer high pressure caps because some cars are designed with high pressure cooling systems. We recommend that you only use a cap with the pressure rating that your car was designed for.
koulee said:0.9 bars! You are definitely gonna blow something at 16 lbs. You ever take a look at the upper radiator hose after you turn off the engine. Its like a water balloon getting ready to pop.
Why would you want to run higher than stock radiator cap pressure? You got twin turbos in that thing or something?
souprat said:i'd just like to point out that 1 Bar= atmospheric pressure= 14.5psi. so he'd be over a bar.
souprat said:no we are both wrong. 14.7 psi. just looked it up in Maximum Boost.
