I'm getting code 51. 7MGTE idles smoothly about 1000 RPM, on the stock Tach and ECU.
I'm getting this Supra ready for Road Racing: So, I removed all the Air Conditioning in the car including the relays and sensors, before I set the ignition timing.
TSRM lists: Code 51 may indicate no "IDL" signal, "NSW" signal or, A/C signal to ECU, during diagnosis check. Would my having removed the A/C relays and sensors be the cause for the slightly elevated idle?
Another symptom: while setting the ignition timing per TSRM, with TE1 and E1 connected in the Diagnostic Block, the idle would only go down to 1200 RPM at 10 degrees and no lower, until I moved the timing to 8 degrees and idle went down to 1000 RPM, which is where I set it. After disconnecting the jumper from the diagnostic block, the timing light showed the timing was around 10 degrees or more, and the idle RPM about 1200.
I next set the TPS, which lowered the idle to 1000. I reset the TPS to lower the idle even more, but then the throttle response was dodgy, causing a hesitation on accel, as if there was a dead spot. Moving the TPS back to the previous setting eliminated the hesitation.
Cold start is very good; starts up in a couple seconds and idles up to around 1800 RPM, then fall slowly down to 1500 in a few seconds, and then gradually down to around 1000 at warm idle. No raw fuel smell noted despite doing a Lexus/550 mod, with AFM by-pass screw out all but the last three threads.
I replaced the old O ring on the by-pass screw, to asure no "pirate air" gets past the opening. I have all new Toyota intake & throttle body gaskets, new HTS silicone couplings and T-bolt clamps, plus new vacuum hoses from Toyota. I used Toyota FIPG on all the gaskets, to assure there are no leaks.
The only thing I will do to test for leaks is to spray some ethanol around all the fittings, while it idles, to see if it idles up.
Any suggestions for what to do next?
Thanks. Van
Thanks. Van
